How To Check For Vaccum Leaks ?
Old Sep 28, 2003 | 02:35 PM
87 LT1 T/A's Avatar
Whats the best way to check for vaccum leaks ? ...... Thanks
Old Sep 28, 2003 | 03:33 PM
ead94z28's Avatar
I used CRC electrical cleaner only because it doesn't leave a total mess on your engine. You can use WD-40 or TB cleaner. Just spray it around the intake maifold hitting all the hose connection and gasket areas with engine running. This stuff is flamable so be careful! Short bursts in suspected area. When idle changes you found your leak.
Old Sep 28, 2003 | 03:35 PM
Hyperspeed97z28's Avatar
really? is that safe bro? I've herd you can use a cig and the smoke from that would be sucked in ??
Old Sep 28, 2003 | 03:40 PM
ead94z28's Avatar
I haven't had any mishaps, and it works like a charm. I was a little nervous when i first did it. Just keep a garden hose close by
Old Sep 28, 2003 | 03:47 PM
Its always good to learn something new
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
