Help With Buying Rotors!!!!
Old Sep 28, 2003 | 02:04 PM
Sssmokin2's Avatar
Question Help With Buying Rotors!!!!
i have a 94 Camaro Z28,,,,,i need a pair of new front Rotors....i would like to get some cross-drilled/slotted ones. does anyone know of any websites that are having specials on some? i know these kind of specific rotors can be expensive,,so that's why i'm turning to you guys with the experience of buying these. i need to get them ASAP. My rotors are SHOT! warped,,,grooves,,all that bad stuff help me out!
thanks
Old Sep 28, 2003 | 02:07 PM
predator's Avatar
www.raceconcepts.net can get all four for 250
Old Sep 28, 2003 | 03:05 PM
Sssmokin2's Avatar
Hey predator i went to the site you provided and i didn't see that you could get all four rotors for $250.00....what i did see was this...
RGM04 Front Rotors $160.00 1993-97 CAMARO EXC. LE PK
RGM05 Rear Rotors $150.00 1993-97 CAMARO EXC. LE PK
which would come to a total of $310.00.......is the $250 some kind of deal you get if you decide to get all 4? please let me know because if i can get em for what you said,,i will,,,if not,,i'm just goin with the fronts
thanks again
Old Sep 28, 2003 | 03:12 PM
predator's Avatar
send them an email or call i got mines for 250
Old Sep 28, 2003 | 03:56 PM
Hyperspeed97z28's Avatar
www.ebay.com
type in "LT1" for search
they offer lots of them...
Old Sep 28, 2003 | 07:27 PM
TreySpeed's Avatar
On permanent vacation
if you want to stop fast, get blank rotors
if you want to look bling- well do what you have to
Old Sep 28, 2003 | 09:24 PM
cndctrdj's Avatar
just get the powerslot from thunderracing and some ceramic pads. absolutly no warping and almost no brake dust. very cheap replacement too
Old Sep 29, 2003 | 04:49 AM
revtime's Avatar
I have Aimco Extreme crossdrilled and slotted rotors.
I got them at autozone for 100 bucks each for the front, you don,t need them for the rear unless you want to, stock rotors work great in the rear.
I had alot of warping problems with stock rotors, so far I have zero problems with these rotors, and they stop REAL good.
I put performance friction pads on as well.
You can get front and rear rotors and brake pads for about 340 bucks.
Not cheap but a pretty good package for street use, and way cheaper than a bear or wilwood package.
Old Sep 29, 2003 | 12:43 PM
96_pimped_out's Avatar
I have these on the front and rear, they're great - fit perfect and the seller (raceparts) ships FAST. I bought the set of 4 for about $170 + shipping. Great value!
http://search.ebay.com/search/search...0&BasicSearch=
Old Sep 29, 2003 | 01:43 PM
IDOXLR8's Avatar
I would also recommend going with Powerslots Remember if you do heavy braking with cross drilled rotors you may encounter some cracking around the holes on the rotor. I have seen this happen a few times.
Old Sep 29, 2003 | 05:00 PM
naztyz28's Avatar
i had the powerslot rotors would never buy them again words cant describe, i now have blanks with hawk pads 120% better.and half the money i paid for the powerjunks
Old Sep 29, 2003 | 05:30 PM
TreySpeed's Avatar
why?
carguy0119
Apr 11, 2016 11:11 PM
HarleyZ28
Oct 5, 2015 06:23 AM
May 1, 2015 01:14 PM
jl1ne
Parts Wanted
Apr 30, 2015 10:46 PM
