auto trans 2.73/ 1st gear blocker shifter question.
Old Sep 28, 2003 | 02:28 AM
ninetythreez's Avatar
where do i cut the 1st gear blocking plate? which piece is it? I have some 3.42 gears coming next week.
Old Sep 28, 2003 | 05:55 AM
MattysTA's Avatar
should be a thick square rubber bump stop towards the 2nd gear side of the shifter. if so then cut the liittle rubber bump stop in half . if you dont have that rubber bump stop. just put the shifter in 2nd and see what is stopping it from going to first and eliminate/fix it. Hope this helps...........
Old Sep 28, 2003 | 01:55 PM
I will look for rubber stopper...
Old Sep 28, 2003 | 02:34 PM
1msfyter's Avatar
Just pull the shifter plate off and pull the shifter down until it stops, you will see the plastic block. about 1/2" by 1/2"
Old Sep 28, 2003 | 05:03 PM
CamaroGuy22's Avatar
Why did GM decide to block off first with cars with 2.73's?
Old Sep 28, 2003 | 06:09 PM
Kain's Avatar
Because they're stupid. Thats my best guess. I had to do the same thing, but since I got the converter I just leave it in drive all the time.
Old Sep 28, 2003 | 07:14 PM
ibanez6rg's Avatar
Looks like I have a project for tomorrow
Can't wait to get rid of my 2.73s
Old Sep 28, 2003 | 07:22 PM
It was due to a noise requirement that was not met when the car was downshifted to 1st gear, so they just eliminated the ability to downshift it. Simple and cheap (and easily remedied ).
Would you rather they put on a more restrictive exhaust instead?
Old Sep 28, 2003 | 07:30 PM
MattysTA's Avatar
yeah i went to 3:73's what a difference.....have fun changing them though its REAL FUN..........
Old Sep 28, 2003 | 07:42 PM
LS1_03's Avatar
Why waste the time and energy to tear apart the console and cut something when all you have to do is yank back really hard? It works in mine.
Old Sep 28, 2003 | 07:45 PM
the main reason I want it out is that I am going to install 3.42s also dude. Soon.
Old Sep 28, 2003 | 07:49 PM
ibanez6rg's Avatar
I try not to be abussive to my car
Old Sep 28, 2003 | 08:02 PM
LS1_03's Avatar
Haha, I didn't mean it like I'm trying to rip the shifter into the back seat. Just a lil tug is all it takes and it's in first.
Old Sep 28, 2003 | 08:26 PM
Ur an abuser JP
Anyways, shoebox, you can shift into first with 3.23 gears correct? So is first gear with 2.73's alot louder than first gear with 3.23's? I am stumped lol
Old Sep 28, 2003 | 08:35 PM
Cmr0z28's Avatar
why would they do it in the 2.73 cars? wouldnt the 3.23 cars go through 1st faster?
