Any way to improve stock WP?
Old Sep 28, 2003 | 12:14 AM
CPM10V's Avatar
Arrow Any way to improve stock WP?
Is there any way to improve the stock LT1 mechanical water pump? What are the primary reasons for them failing? I'd much rather have an "improved" mechanical pump than an electric pump. I have one off a '97 Z28 to mess with and work as tool and die maker so have the resources to modify it. I just wanted to know what could, if at all possible, be improved on it. Impeller, bearing, seating surfaces . . . Any info appreciated.
Greg
Old Sep 28, 2003 | 12:30 AM
Compstall's Avatar
Can't do much with it. I have an extra myself off of a '94 Vette that I'm sanding and polishing with some leftover sanding rolls. Once mine goes bad I'm gonna put the shiny one in with an electric pump.
Old Sep 28, 2003 | 12:39 AM
CPM10V's Avatar
Yeah, I know the Meziere/CSI pumps flow more and free up a little more power but there's a major reliability factor there IMHO. I'd just like to improve what's there if possible. If not feasible I'll just use a stock WP.
Greg
Old Sep 28, 2003 | 10:16 PM
arnie's Avatar
Originally posted by CPM10V
Yeah, I know the Meziere/CSI pumps flow more and free up a little more power...
Correction, the electric pumps ( meziere for sure) flows appr. 52-55 gpm in an LT1, which has a more effecient cooling system. Std. sbc flows around 50, I believe. The oem mechanical pump flows appr. 80-85 gpm. SW has stated an LT1 pump is in the works. However, the arrival date keeps getting set back. Anyway, SW states that mechanical pump will flow appr. 115-120ish gpm., if I remember correctly.
BTW, the 80-85 was a guesstimate of mine, that was later substantiated by SW (Stewart Warner) on their forum.
Old Sep 28, 2003 | 10:27 PM
i387's Avatar
The only problem with the mechanical pumps is their flow rate depends on engine RPM. So while you are in bumper-to-bumper traffic and idling, the mechanical WP is seriously lacking.
With a electrical WP, the flow is the roughly the same no matter what the RPM. Not to mention less parasitic loss. They can also be wired (along with the fans) to run when the engine is not running.
Each has their place.
Old Sep 28, 2003 | 10:36 PM
arnie's Avatar
Originally posted by i387
The only problem with the mechanical pumps is...
Agreed! However, for those that operate at high rpm for an extended period of time, should not expect the electric to deep the engine cool. For oval track use, expect to need a minimum of 100 gpm.
Old Sep 29, 2003 | 01:35 AM
Compstall's Avatar
Arnie the Rainman....
Old Sep 29, 2003 | 01:39 AM
madwolf's Avatar
Someone posted a while ago about how he designed some sort of tube that connected to the weep hole on one end and the other end was sticking out as far as possible from the opti. I thought that was a good idea to protect the opti, only it would probably be sort of a PITA to do without the right tools. (which you probably have)
Other than that, I don't think there's much you can do to improve it.
Old Sep 29, 2003 | 01:53 AM
kevkop94TA's Avatar
Wink
ROFL!
ROFL!
ROFL!
Old Sep 29, 2003 | 05:00 PM
CPM10V's Avatar
Thanks for the replies and clarifying the electric/mechanical flow ratings. Any more info. about the SW (Stewart-Warner?) LT1 pump?
Old Sep 29, 2003 | 06:51 PM
arnie's Avatar
Any more info. about the SW LT1 pump?
Tell ya what! I'll send ya here, in case you'd like to inquire and/or check around for yourself: http://www.stewartcomponents.com/html/forum/default.asp
Good info there. As for me, haven't heard lately.
Old Sep 29, 2003 | 06:56 PM
arnie's Avatar
Good info there. As for me, it was spring, when I got my latest (not ready yet) update on the LT1 pump.
canbaufo
May 25, 2015 12:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
CARiD
Jan 27, 2015 06:27 AM
Brian-94TA
Jul 31, 2002 02:52 PM
