Passed the sniffer
Old Sep 25, 2003 | 09:03 PM
ChuckZ28's Avatar
Smile Passed the sniffer
Took my car to the sniffer test today and passed no problems. I was a little worried that it might not make it with the size cam I have but the computer tunning that Tracey Scott did for me when he did my cam was excellent.
Reading Limit
HC 97.4 , 114.0 ppm
CO .30 , .63 percent
NO 82.6 , 796.0 ppm
CO2 14.55 , N/A percent
Old Sep 26, 2003 | 01:22 PM
llafro's Avatar
What is the duration and LSA on your cam? That's more important than anything else when it comes to smog. I'm curious to see what my car will do.
BRAD
Old Sep 26, 2003 | 01:24 PM
atljar's Avatar
BRAD
I think his is 236/242 ? Or something right along there. Chuck...did it have cats on it?
Old Sep 26, 2003 | 01:59 PM
bigdreamZ's Avatar
BRAD
I am curious as well. If you pass with that cam I am swapping out my 305 for that right away. When is your car due for a smog? Keep us posted on the results.
Old Sep 26, 2003 | 03:35 PM
anaik's Avatar
Better find out what the limits are in CA first, might be tighter.
Old Sep 26, 2003 | 03:53 PM
AndyB's Avatar
From my smog test last week:
http://www.jbelectric.us/ot/ImpalaSS...mogresults.pdf
#'s for the dyno type (strictist) smog test there is
Max HC
15mph 79
24mph 44
Max Co
15mph .45
25mph .42
Max NO
15mph 677
25mph 680
So that cam would fail in Ca due to excessice Hydrocarbens (which I think would be due to the tighter LS)
Old Sep 26, 2003 | 04:00 PM
atljar's Avatar
This is from my buddies 234/242 just for comparo.
847 emissions. buddy just took his 383 through, 847 cam, race port lt4s, longtubes etc.
288.8 HC, limit 99........fail
1.47% CO, limit .55%...fail
co2 12.87, limit na
He has the FLP setup, just went back today with the cats on it.
HC 23.2, limit 99.......pass
0% CO....limit .55%....pass
Old Sep 26, 2003 | 04:02 PM
AndyB's Avatar
What was his NO readings?
Old Sep 26, 2003 | 04:08 PM
atljar's Avatar
I'll have to get with him, i pulled those numbers from a post i made awhile ago.
Old Sep 26, 2003 | 05:29 PM
FacelessZ's Avatar
so many people worry about emissons...why not just slip an extra $10 to the guy? after all, they just have the stickers laying around...
did I just say that?! oops
Old Sep 26, 2003 | 05:38 PM
AndyB's Avatar
I wish it worked that way in Ca. Try about $1,000+ to do that in Ca if you can even find someone.
Fines for a mechanics doing that out here are enormous plus jail time. So not to many mechanics are willing to put themselves on the line for a few extra bucks.
Old Sep 26, 2003 | 06:16 PM
TimChiaretto's Avatar
And in California if you have an OBDII system you get plugged into the computer that reads your VIN and transmits the data to the state. It would be hard to fake that one.
Old Sep 26, 2003 | 07:09 PM
ChuckZ28's Avatar
112 degrees lobe sep and 236/244 duration. I still have track tunning to do coming up soon which is good because ive yet to run it with the cam and the extra bit of tunning should help some more too. This was with the cat on it but its got a hole the size of a quarter that I put in all the way through when I first got the car. Im welding up a straight pipe now to get rid of the cat for bolt in and out. This was also done with no AIR pump and blocked EGR.
David Dempsey
Mar 12, 2016 12:42 AM
4586
Sep 6, 2015 03:10 PM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
karpetcm
Aug 14, 2015 03:02 PM
Cam's maro
Aug 11, 2015 07:45 AM
