shoebox 1 more Question
Old Sep 26, 2003 | 08:14 PM
StangInRearView's Avatar
i have it wired like that, but what can i use to hook up the 12v. I htought the stereo only came on when the ignition was on, thanks for the help.
Old Sep 26, 2003 | 08:50 PM
You need to reference a post or something. I am going to guess you are talking about a fan switch. Use a meter or test light to find a power wire only hot with the key on. Most pink ones should work. You can also run a wire to one of the "ign" ports at the fuse panel.
Old Sep 27, 2003 | 03:37 AM
revtime's Avatar
Shoebox:
What am I thinking right now?
Old Sep 27, 2003 | 04:27 AM
96 WS6's Avatar
I can help with this one... well at least I know where to tap the underhood fuse box. Take it off and towards the left end on the bottom there should be 3 or 4 thin pinkish wires. Any one of them should do the trick. You are just looking for 12+ Ignition switched correct? You could also pull that from the in car fuse panel. Just look for an accessory that only gets power with the key on.
Old Sep 27, 2003 | 08:16 AM
scoobysnax83's Avatar
The entire fuse box under the hood is switched power.
Old Sep 27, 2003 | 08:17 AM
Got it, thanks a lot guys for the help Mike
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
