whole optispark or cap n rotor
Old Sep 26, 2003 | 07:39 PM
1badasZ's Avatar
Question whole optispark or cap n rotor
is it ok to just repalce the cap and rotor on the optispark or do i need to buy the hole unit? and is the cap n rotor you get at the local parts store as good as the dealer part?
Old Sep 26, 2003 | 07:42 PM
Z95m6's Avatar
most of the time i have heard the rebuilds don't really work so it cost way more to buy the rebuild kit and then have to buy a whole opti afterwords. Just get the GM opti now.
Old Sep 26, 2003 | 07:58 PM
Fastbird93's Avatar
No, just pony up the extra few bucks and buy a new one. I made that mistake, and it was an expensive one!
Old Sep 26, 2003 | 08:22 PM
RamAir95TA's Avatar
Yes...purchase an ENTIRE GM optispark, not just the cap and rotor.
Old Sep 26, 2003 | 08:46 PM
Josh-'04 GTO's Avatar
I'm on the whole opti bandwagon too! The whole unit was only $197 shipped to my door from Dal. Definately not worth messing around with a cap and rotor for that price.
Old Sep 27, 2003 | 03:54 AM
revtime's Avatar
My cap and rotor was very bad but the optical part was ok, the bearing was shot though. Get the whole opti and save yourself the hassle.
Just for the record I got mine from Advance auto and have not had any problems but for the price you might as well get the GM one.
Old Sep 27, 2003 | 04:19 AM
predator's Avatar
when i took my opti out after 120,00 miles the optical disk was rusted and the bearing was almost falling apart. get the whole opti besides i have heard thatcap and rotors go for around close to 200 you can get the whole thing from samtaylor.com for 250 or so
Old Sep 27, 2003 | 04:28 AM
InjectedSS's Avatar
what year is your car? if you have a 95+ then go to autozone and ask for #30-1833 that's the CAP, ROTOR, AND DISTRIBUTOR all in one kit for $130.00 LIFETIME WARRANTY
Old Sep 27, 2003 | 10:28 AM
marshall93z's Avatar
why is the 93 and 94's higher? and also what all is needed for the conversion to the newer one?
Old Sep 27, 2003 | 10:43 AM
notstock4long's Avatar
Man, you are lucky. I have tried it threee times now, and keep getting just the optical sensor part of the opti, without the cap and rotor
Old Sep 27, 2003 | 10:46 AM
The 93 and 94 optis are non-vented, so that makes them like a $100 more I guess. I will try to find the page that shows everything you need for the swap to a vented, which I think is worth it.
Old Sep 27, 2003 | 05:59 PM
http://para.noid.org/~muttvette/opti.html
Old Sep 27, 2003 | 07:00 PM
Compstall's Avatar
Do what you want. I changed the cap and rotor only 20,000 miles ago and I haven't had any problems.
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
jayblev95
Sep 26, 2015 09:44 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
heus
Sep 8, 2015 12:01 PM
