what my CR when i mill my heads
Old Sep 25, 2003 | 03:20 PM
97Z-M6's Avatar
what would be my new compression ratio if i tok off .020 of my stock heads. every thing else is stock.
Old Sep 25, 2003 | 04:11 PM
amean94ta's Avatar
we just did this at work today it will raise 0.25 cr for every .010 you take off same with using thinner head gaskets so say you have 10.1 cr you will get 10.150 with 0.20 shaved if you took off 0.40 it would be 10.2 so this is not a very good way if your seeking higher comp.
Old Sep 25, 2003 | 04:24 PM
You started off real good... with a 4" bore, you get +0.25 compression units for 0.01" cut. Then you lost it....
That would mean a 10.4:1 engine would go to 10.4 + 0.25 = 10.65:1. For a 0.02" cut, you get +0.50 units, or 10.9:1
Old Sep 26, 2003 | 01:38 PM
marshall93z's Avatar
what is the stock PTV clearance? and what is safe?
Old Sep 26, 2003 | 05:21 PM
amean94ta's Avatar
.................................................. .................................................. .... thats ok i was over hearing the conversation my cousin who owns krs machining was talking to a customer on the phone atleast i tried lol
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Dec 28, 2014 06:20 PM
