Misfire
Old Sep 27, 2003 | 08:45 AM
ead94z28's Avatar
Question Misfire
Anybody have any suggestions on what would cause a misfire in the #3 cylinder? Dealer said he thought there was one. Plugs, wires and injector all working properly.
Old Sep 27, 2003 | 10:24 PM
Josh-'04 GTO's Avatar
Re: Misfire
Did you swap the plugs, wires, and injectors around...and still get a misfire on #3?
If so, I'd have to say the opti could be at fault.
Old Sep 27, 2003 | 11:22 PM
GrdLockV6's Avatar
Start the car up and check under the hood while it's pitch black dark outside. Look for some faint blue light coming from near the wires, it could be grounding out on the manifold.
Otherwise if you're sure it's not a bad plug or something, it's probably the opti.
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
Schul365
Aug 22, 2015 10:00 AM
Girrrrl
Aug 20, 2015 09:26 AM
zajones
Jul 30, 2015 02:18 PM
