Quick..Fanswitch Problem
Old Sep 26, 2003 | 05:20 PM
StangInRearView's Avatar
i just finished installing a fan switch with LED's, i hooked the power source up to the yellow stereo power wire, it works great, but the LED's stay on when the car is off, this is on a '94 OBD -1, is there an alternative power source i can hook it up too in order to have the LED's shut off the same time the car is off.
Also, when i was tapping into the blue and green wires, i noticed a white wire, with a connector on the end reading "PED 9", this wire is coming from the main group of wires coming from the firewall, it is not connected to anything, and i dont know where to connect it too, is this a bad thing?? can someone please help me find where it goes.
Thanks, Mike
Old Sep 26, 2003 | 06:39 PM
You either need to use a power source that is only on when the key is or you need to add the diodes that are in this diagram.
The lead you are seeing is probably a gray wire that is the fuel pump prime connector. It is not meant to be connected to anything. It is just there for test purposes.
Old Sep 26, 2003 | 08:11 PM
thanks
thanks shoebox, but i have one more question, what 12v source can i use, i thought the stereo one was only on when the key was on.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
