Defective lifter?
Old Sep 27, 2003 | 01:55 AM
M93Z's Avatar
Defective lifter?
I just installed new comp lifters after soaking them in oil overnight. When I set the lash on the roller rockers I had one lifter out of the sixteen that felt soft. The half turn after zero lash can be accomplished by hand while the others required a wrench. Should this lifter pump up when I start the car or is there a problem with it? Better to find out now while the motor is apart.
Thanks!
Old Sep 27, 2003 | 11:47 AM
M93Z's Avatar
Old Sep 28, 2003 | 02:34 AM
xchief1320's Avatar
honestly i wouldn't worry about it as long as nothing seems "broke" like a busted clip ect..
I have done alot of cam swaps on various engines and alot of the times a few of the lifters will be real easy to push down like that when they are new.After they fire up and get oil pressure the looseness goes away..
Steve
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Alibi
Aug 1, 2015 07:50 PM
