Header Gasket with High Temp Silcon Gasket Maker ?
i would do it, i had some , and now i regret not doing it because i have a header leak i gotta worry about now
i say just go ahead and do it, its only like a couple dollars just for the added insurance
In my opinion you shouldn't need that stuff. As long as you use a quality header gasket and your header flange is flat, you shouldn't have any leaks. Plus when it comes time to change the gasket again you have to clean up all the old sealant gunk.
I've had the same pair of Fel-Pro gaskets in my car without any RTV for over 2 years now without any leaks.
