Smooth Bellows?
Old Sep 27, 2003 | 07:53 PM
ZZtop's Avatar
Smooth Bellows?
I need to replace the ribbed tube from my MAF to the throttle body, so I would like to replace it with a smooth piece. Does anyone know where I can order a smooth bellows as its called or if the one for the LS1 will fit my LT1?
Old Sep 27, 2003 | 08:45 PM
SWINGRRR's Avatar
Try a search for "Fernco" I think that was the name of it. The Moderator, Injuneer started using these things.
Old Sep 27, 2003 | 08:46 PM
You can buy one from SLP for about $30. Or you can go to Home Depot (or similar hardware store) and buy a Fernco part # 1056-33 3"x3" sewer pipe connector, with 2 clamps for $5. Heat the connector in hot water, and it will slip right over the throttle body.
Fernco connector
Jeff1904
Jun 5, 2016 05:00 PM
Bxlt1
Sep 29, 2015 03:18 PM
mlopezart
Sep 8, 2015 12:15 PM
karpetcm
Aug 14, 2015 03:02 PM
