horrible miss under 2000rpm
Old Sep 28, 2003 | 11:51 AM
always2fast4u's Avatar
hey.
I have develeped a bad miss in the motor under about 2000rpm in any gear. It happens when you put the pedal down, and it shakes really hard and has a tough time getting speed up. After you hit around 2000 rpm, the shake goes away and the motor runs strong. I wasn't sure if it could be timing or a clogged fuel filter or what. I need to find out what it could be before I go investing in parts that isn't guaranteed to work. Thanks.
John
Old Sep 28, 2003 | 12:13 PM
Hyperspeed97z28's Avatar
I would change the fuel filter either way.. Most likely you prolly need to do it.. even if it doesnt help the miss. your helping your car out by doing it... as for the miss.. could be your ICM/COIL/ BAD PLUGS/BAD WIRES. or at the worst the OPTI..
Try testing the ICM and COIL.. check for arching of the wires at night by maybe jackin the front end up and running the car for a few.. you'll know if your arching... let us know what u find..
Old Sep 28, 2003 | 02:50 PM
thanks.
i just put plugs in, so is there a possibility that if I broke one, it is causing the miss only at low rpm? The wires should be good but I will check them anyway.
Old Sep 28, 2003 | 03:01 PM
Rodrigues's Avatar
I guarantee you its ignition related, probably ripped the core of a wire doing the spark plug install. 99.9% sure its NOT the opti.
93 RedBird
Nov 15, 2015 08:24 AM
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
Bigfatrat
Parts Wanted
Oct 4, 2015 08:54 PM
Ks0209
Oct 1, 2015 07:32 AM
tommalcolm
Sep 11, 2015 03:39 PM
