Will an LS1 10 bolt rear work in a 97 LT1 car?
Old Sep 28, 2003 | 12:16 PM
JTS95TA's Avatar
My 10 bolt with 3.73 gears got toasted the other night at the track. I found a guy who has a stock 3.42 10 bolt near me out of a 01 SS. My car has traction control and so does the rear end the guy is selling. Will there be any issues with anything such as brakes, ABS, traction control. I am assuming (but not 100% yet) that I would be using my original axles and LT1 brakes. If anyone has done a LS1 rear to LT1 car swap let me know if there are any issues at all. I need to get another rear in this car asap.
Old Sep 28, 2003 | 12:24 PM
Hyperspeed97z28's Avatar
You'll just need to swap your backing plates and brakes off your current rear to the ls1 or you can upgrade to the ls1 rear brakes.. i think you'll only have to swap over your backing plates in that case... I'm sure others will chime in...
Old Sep 28, 2003 | 01:13 PM
lietuvis's Avatar
It will fit, butyou will need a set of ls1 rotors. Also, you will not have parking brake
Old Sep 28, 2003 | 01:50 PM
well he can keep the lt1 brakes and put them on the ls1 axle and then retain the e brake with no other fitment problems...
Old Sep 28, 2003 | 04:21 PM
JTS95TA's Avatar
Alright thanks guys now that I think about it the caliper brackets are just bolted on so I dont see why I cant just bolt mine right onto the new rear end.
Hopefully it works like that.
Anymore input is appreciated.
Old Sep 28, 2003 | 04:26 PM
Yeah thats all u have to do bro.. Change your backing plates from the lt1 axle to the ls1 axle.. its pretty str8 forward...
Old Sep 28, 2003 | 05:49 PM
mycarisfasterthanyours's Avatar
They will bolt on, but you will have to slide the axles out in order to swap them. Pretty straight forward though.
Lederman1976
Nov 30, 2014 05:21 AM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
