LCA bolt size?
Old Sep 28, 2003 | 05:11 PM
Rodrigues's Avatar
LCA bolt size?
I did a search and coul not find the bolt sizes for the lower control arms. Does anyone know?
Old Sep 28, 2003 | 06:49 PM
Rear lower control arm bolt
M12 x 1.75 x 95
GM PART # 11502603 if you want to get them from the dealer. They are high grade bolts.
GM PART # 11515744 for the nut.
GM PART # 473539 for the washer.
Old May 8, 2004 | 11:00 PM
Spinner's Avatar
up for personal reference
Old May 9, 2004 | 09:31 AM
Spohn Performance sells an LCA bolt replacement kit for $9.95:
(4) 12mm Grade 10.9 bolts (silver zinc plated)
(4) 12mm steel lock nuts (silver zinc plated)
(8) 12mm flat washers (silver zinc plated)
http://www.spohn.net/product.cfm?productid=1408
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Jan 11, 2015 03:47 PM
