Do you own one of these Duel setups?
Old Sep 26, 2003 | 01:07 AM
PoorMan's Avatar
Converting my Lt's over to duels. I have a found couple pics that I want to copy for my own setup. Anyone have either of these.
I like this one because it's going to be the cheapest. What do you think about the pipes exiting in front of the rear tires? I think it would look sort of cool as long as the tips are angles right and not to big. I suppose the H-pipe is still as functional when its that long?? If I went this route I would weld the mufflers after the H-pipe though. I think this setup doesn't have muffers at all because I can see an O2 sensor after one of them. Those maybe CATS. Anyway.
http://community.webshots.com/photo/...92033010hslbtm
This next one appears to be the universal Hedmen x-pipe kit that summit sells. This looks to be the 2 1/2" one because he has reducers on the collectors. They also have a 3" kit btw.
http://community.webshots.com/photo/...92032866zZDXLR
The thing is, here in Shreveport, nobody, I mean nobody does mandrel bends let alone any type of performance exhaust. I am looking for more of a Weld-On type system that I can order so I can do it myself. What do you guys thing?
Jeff D
Old Sep 26, 2003 | 04:47 AM
madhatter's Avatar
well, if no one has a mandrel bender then you can always take prebent pipe and cut it and piece it together. that is how my setup is. Very clean looking just like that. I don't care for the angled tailpipes on our cars, but that is my .02.
oh and
du·el
1 : a combat between two persons; specifically : a formal combat with weapons fought between two persons in the presence of witnesses
2 : a conflict between antagonistic persons, ideas, or forces; also : a hard-fought contest between two opponents
du·al
1 : of grammatical number : denoting reference to two
2 a : consisting of two parts or elements or having two like parts
Old Sep 26, 2003 | 05:07 AM
97LT1F-Body's Avatar
Originally posted by madhatter
oh and
du·el
du·al
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
FryedClutch
Sep 1, 2015 08:24 AM
