What wires on jet hot LTS
Old Sep 26, 2003 | 01:46 AM
unTAmedLS1's Avatar
what wires and setups for wires you guys running becaus emy msds suck horribly....I will never buy again they are arching through the insulation without even being burned
Old Sep 26, 2003 | 09:29 AM
Brettinator's Avatar
that's very rare, it has to be cut because they just don't do that. Taylor makes a good wire that has a smaller boot which works well with the Jethots. I'd see if they'd warranty a new set in your situation. 9 times out 10 it's a wire that got too close to a primary and is cooked which starts the arching.
good luck
Old Sep 26, 2003 | 09:31 AM
ibanez6rg's Avatar
I'm using OVC with Taylor wires.
Old Sep 26, 2003 | 10:53 AM
I considered doing that setup with the heat sleeves, etc. But knowing the stroker will get a solid roller cam I would be perodically setting valve lash and didn't want to have all that in the way. How much work is it really though, to move them that is?
thanks
Old Sep 26, 2003 | 11:04 AM
ibanez6rg's Avatar
thanks
I personally see it as a pain in the *** Seriously though all you have to do is take the bolts out and move the looms and wires to the side.
Old Sep 26, 2003 | 01:55 PM
unTAmedLS1's Avatar
Yeah I was thinking about the otvc kit alsoa nywhere cheaper than 99.99 for everything?
Old Sep 26, 2003 | 02:00 PM
revtime's Avatar
I run MSD superconductors in the stock locations basically, I have 2500 on the LT install and not 1 burnt wire.
I really like the MSDs they are the best wire I have found to date.
Old Sep 26, 2003 | 03:16 PM
RamAir95TA's Avatar
I too, run a Taylor OTVC combination with Made-For-You looms, and wouldn't really use anything else.
HarleyZ28
Oct 5, 2015 06:23 AM
Critter
Jul 7, 2015 08:33 PM
Fatdog2
Mar 31, 2015 06:50 AM
LT14LIFE
Feb 9, 2015 09:35 PM
