Got back from maple grove ... is my engine dying?
Old Sep 27, 2003 | 09:15 PM
wayne97's Avatar
Alright please read this whole story and give me an opinion if you have one. I just took my car to the track after putting on my torque converter earlier this week. One my first run, I started out okay i thought, but my car just wasnt pulling well after my 60' and my mile per hour was 92 with the mods you see below. PROBLEM! Anyway I figured maybe my car was fine and I just was being too easy and wasnt on the gas like i should have been. Well, my second run was far worse!! 15.3 @ 85!!! On my way back to the pits, It sputtered and died. It turns over still, but makes a whiny squeal coming from the back of the engine I believe. A couple people suggested my flexplate. My car idles low all the time because of my underdrive pulleys, so maybe with the friction of a possibly bent flex plate that caused my engine to sputter and die when I was poking back to the pits? I can only start it with the gas pressed lightly, otherwise it turns over almost enough to start but not quite. Once it starts a that hideous squeek emerges again! I'll try to describe it as best I can if you have any other questions ... any help would be much appreciated...
Jonah
Old Sep 27, 2003 | 09:43 PM
wayne97's Avatar
anyone have an idea?
Old Sep 27, 2003 | 11:05 PM
People seem to talk all the time about getting the converter on correctly. If you don't, I believe it can screw up the tranny pump. I have not actually done one, so I am just passing on what I have read here. Something about 3 clicks or some such thing. You might want to try a search to see what you can come up with.
Old Sep 27, 2003 | 11:16 PM
xxsaint69x's Avatar
oh he got it on right if he drove the car
If u dont, your pump will get crushed when the tranny is bolted up and the car wont move Guess how i know...
Marcin
Old Sep 28, 2003 | 12:40 AM
Compstall's Avatar
Maple Grove......isn't that where Barney, Opey, and Ain't 'B live? Gee Pa, I'm not sure what's ailin' yer tranny..
Alex Barnes
Jan 24, 2015 10:21 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
A's 91 Z28
Jan 11, 2015 10:58 AM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
