Intake manifold leak questions.
Old Sep 26, 2003 | 08:38 PM
Z-RATED94's Avatar
I reached behind the motor on the drivers side and nearly got my arm stuck. Anyways when I pulled it out there was a small amount of oil on my hand from the intake manifold. Does this mean I've got the infamous LT-1 vacuum leak? The last time the car was at the track it was disappointing to say the least. And the car seems a little flat under WOT. Other then that it seems to run ok under normal driving. Is this possible? Could a leak like this cause the car to run at least a half second slower than what it should?
Thanks for any help!
Old Sep 26, 2003 | 08:50 PM
RCF925's Avatar
When I had that infamous Intake leak the car ran great, Just had Oil all over the freaking place. Unless you can do a Vacuum check you won't know, But a Vacuum leak will make the car run poorly
Noer
Feb 28, 2015 11:29 AM
alex5366
Feb 17, 2015 08:12 PM
CARiD
Jan 27, 2015 06:27 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
