EGR Help. What can I do?
Old Sep 26, 2003 | 05:05 PM
WhiteBeast's Avatar
Question EGR Help. What can I do?
Ok, I have been having a service code display that the EGR Valve is bad, code 32 or something like that. What i need to know is what is all of this talk about deleting the EGR valve?
What does this accomplish? Also will i still be displaying a service code if i delete it?
Old Sep 27, 2003 | 10:37 PM
Josh-'04 GTO's Avatar
Well, you can choose to delete the EGR valve and its ancillary components. This gets rid of a few pounds off your car, and gets rid of a system that you really don't need. Simply unbolt the EGR valve, tube, and solenoid and discard. You'll need blockoff plates (use SJM Manufacturing) to cover the holes in the intake manifold and exhaust header/manifold. I'm not 100% sure about OBD I cars, but on OBD II you'll set a code. I chose to eliminate the codes through LT1 Edit.
If you're not into modding your car, you can simply replace the EGR valve. There was a recall on them, I think older LT1 versions tending to carbon up easily.
Old Sep 28, 2003 | 01:46 AM
Chris 94Z A4's Avatar
Post
The best thing to do is to replace the EGR valve.
Kinglouui
May 26, 2016 11:05 AM
David Dempsey
Mar 12, 2016 12:42 AM
truecontr3
Oct 11, 2015 09:30 AM
surreybrad
Sep 29, 2015 09:00 PM
damnyankee36
Sep 9, 2015 07:06 PM
