ABS Lights after cam install???
Old Sep 28, 2003 | 11:00 AM
Z_Maniac's Avatar
Does anyone ever had their ABS lights stay on after a cam install? My mechanic just finished installing a CC305 cam, CC1.6RRs, Hooker shorties and after all is done he took the car around the block for a test drive and now the ABS light stays on??? Also, he indicated that the brake system is slightly firmer to push down and if he would've done a panic stop he wouldnt be able to stop in time???
I'm alittle confused because I've never heard of this happening to any of my other buddies.
Old Sep 28, 2003 | 11:07 AM
Hyperspeed97z28's Avatar
check all wheel sensors.. check your abs box, make sure all the connectors are plugged in.. I had an abs light on after my header install for 6 months before figuring out it was just a connector not plugged in.. I even had my abs system scanned and the whole 9 yards... Most likely something got unplugged and not replugged in.. good luck
squarehead
Jan 15, 2015 07:02 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
