Do Hypertech make a failsafe 160 tstat?
Old Sep 26, 2003 | 09:28 AM
lbrowne's Avatar
Just as the topic says, I have to replace mine since its after stickin on me a couple of times.
Old Sep 26, 2003 | 09:34 AM
MentalCaseOne's Avatar
IMO all parts will eventually fail.
I have a 160* thermo by hyphertech. Its working just fine however I only expect it to survive as long as the OEM. No more no less. If it last longer it will be a bonus.
Marvin
Edit: BIG OOPS... I just realized you are referring to the 160 thermo being replaced... Well, I havent heard of an upgraded/failsafe version.
Old Sep 26, 2003 | 09:46 AM
lbrowne's Avatar
yeah this is crazy, i had this tstat for about 3 years. 22k Kilometers driving total....not sure what that is in miles.
Old Sep 26, 2003 | 09:52 AM
i387's Avatar
The Hypertech 160 that I bought had a hole pre-drilled in the platter (?) for steam ventilation. But it's not large enough to flow enough coolant if the unit fails.
As far as I know, there are no thermostats that are failsafe. They are normally closed because of spring pressure, when they fail there is nothing to overcome the spring. They stay closed.
Hmm... Makes you wonder why someone doesn't design one that works in reverse. You know a "pull" spring that opens the diaphram with a heat element that tries to pull it closed until the temp is reached. Hmm....
Any inventors on this board?
Old Sep 26, 2003 | 10:31 AM
lbrowne's Avatar
Crappy tire has failsafe tstats, had them for quite some time. But they are not Hypertech and I can not get one in 160 for my car.
What happens is if they fail, they still allow coolant into the engine...something like that.
Old Sep 26, 2003 | 11:40 AM
moparman's Avatar
Google for "motorad thermostats". They make a failsafe thermostat. Don't know who sells them, or if they have one for the LT1.
MattFick
Feb 15, 2015 10:16 PM
Jason Short
Jan 19, 2015 06:34 PM
Chicago94Z28
Aug 28, 2002 08:31 PM
slothgrant
Aug 22, 2002 03:01 PM
