Dynaspark Install question
Old Apr 2, 2005 | 08:29 AM
TEG99SS's Avatar
Question Dynaspark Install question
The new dynapsark is here, has anybody installed one of these? Is there anything I am going to run into that is different from installing the stock opti?
Old Apr 2, 2005 | 10:22 AM
nateh's Avatar
Re: Dynaspark Install question
If you follow their directions exactly, you won't have too much trouble. It's only different in that you have to put a new connector on. The directions on mine were perfect and I had no trouble.
By your sig, you don't have an aftermarket cam so dowel pin length shouldn't be a problem. Some cam manufacturers ship cams with the dowel pins too long and it will stress and eventually kill the internal bearings.
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
nautilus
Aug 22, 2002 11:49 PM
Chrisdude
Jul 24, 2002 02:25 PM
Brent94Z
Mar 21, 2002 04:44 PM
