Stock CC on lt1 heads? I keep hearing two answers.
Re: Stock CC on lt1 heads? I keep hearing two answers.
Damn it, which is it?
http://web.camaross.com/forums/showt...stion+chambers
Gmpartdirect has lt1 heads listed as 58cc:
http://www.gmpartsdirect.com/perform...CATID=856.html
i just did a set of aluminum heads for my friend's 96. i cc'd the chambers and got right at about 57cc on all of them and i polished them. so, i did a little grinding in them but i'm pretty sure i didn't remove much material. i was happy that they were all extremely close to the same cc without having to touch anything up!
ive heard 58 too.
ive also heard LT-4 = 53.4 , or something like that.
and LT-1 are 56.something.
i think people round the numbers and call LT4s 54cc and LT1 56cc.
i dont see the LT-1 heads being 54 or less, if that was true then the LT-4 would have to be as little as 52cc. if you change the head on and LT1 to LT4 heads your compression goes from 10.5 to like 11.1:1
one of the site sponsor should know. like combination motorsports......
well then what friggin size are LT-4 heads???????
BTW, summit advertises their CR on their rebuild kits for the LT-1 with 58cc heads.....so is the unsuspecting guy that is rebuilding his stock LT-1 gonna have a lot higher CR????
Here it says "a bit more than 53"
http://www.chevyhiperformance.com/techarticles/4606/
The pattern looks like there's a 58 number from some official source, but measured numbers are more like 53-54.
