Front and Mid mount motor plates, any significant advantage?? Who uses them??
Re: Front and Mid mount motor plates, any significant advantage?? Who uses them??
Unless you have a trailer queen there is no need for them. If you aren't running in the nines there is no need for them.
The big advantage is you can put the engine where you want and the mid plate helps with broken bellhousings.If you use both motor plates don't use a solid tranny mount,you will break the tail housing.
Richardan15
May 30, 2015 08:36 AM
heavenly_six
Dec 10, 2014 12:23 AM
