425hp !!
Old Apr 2, 2005 | 04:10 AM
vonmoldy's Avatar
425hp !!
The GM LT4 converision lists horsepower increase to 425. Is this true? Has a magazine or website ever tested this? How could they claim this if it isnt true?
Old Apr 2, 2005 | 04:16 AM
JBird33's Avatar
Re: 425hp !!
It may be on the optimistic side, but it isn't RWHP they are claiming - it is flywheel horsepower. It is generally considered to be overpriced compared to vendors like Lloyd Elliot and the like. If you look around, you can find much cheaper kits that produce more power.
Camaro97USAF's Avatar
Re: 425hp !!
Maybe flywheel if your lucky.
Old Apr 2, 2005 | 07:17 AM
TransAm2k4's Avatar
Re: 425hp !!
That should be something around 340-360 on the wheels (Calculated not really sure)
Old Apr 2, 2005 | 09:30 AM
Antz97ZNJ's Avatar
Re: 425hp !!
Yea theres much cheaper heads/cam options
Old Apr 2, 2005 | 09:57 AM
96capricemgr's Avatar
Re: 425hp !!
What everyone has said sofar is correct but I think I can help put it in better perspecive. If your stock motor was tested under those same conditions it would be over 350hp. Does that make the point clearly enough?
Old Apr 2, 2005 | 10:39 AM
Z28WannaB's Avatar
Re: 425hp !!
That kit is way over priced, there are much better choices. I am including an LT4 shortblock in my build and it will still come out cheaper than the kit.
- Z28WannaB
Old Apr 2, 2005 | 10:58 AM
Re: 425hp !!
The HP numbers used in advertising are based on an engine dyno (no accesories, no other losses) done by MORE Performance in the late 1990's. The magazine article has been reprinted a couple times since then. They used LT headers, larger TB, larger injectors, and the thing they fail to mention... the engine was tuned with a $3,000 aftermarket ECU. They got 429 flywheel HP. In effect - SAE "gross".
Old Apr 2, 2005 | 11:04 AM
Tair's Avatar
Re: 425hp !!
good explanations. i was wondering about this too.
Old Apr 2, 2005 | 11:10 AM
ZPaul2Fresh8's Avatar
Re: 425hp !!
Yep, Lloyd is the best bang for your buck.
Old Apr 2, 2005 | 11:13 AM
96m6lt1's Avatar
Re: 425hp !!
it's another one of those "power packages" like edeldrock sells.it is really just designed for the person that knows very little about performance upgrades it is foul proof and motor safe,however if you read others posts to see what parts work best with others you will find a better set up between $$$$ and the power the combo will generate for you,my best suggestion is to contact Mr.Elliot @E-PORTWORKS this man is a wizzard and can set you up with a nice combo,remember this, the biggest bang for the buck is goood head
D.S.R.E.
Classic Engine Tech
Mar 15, 2012 01:34 PM
Rob@WretchedMS
Sep 17, 2009 07:02 AM
Jason E
54
Jan 19, 2007 07:38 AM
backinblack2002
Aug 18, 2003 10:41 AM
RyanS_Z28
Jun 22, 2003 12:50 PM
