Need Help Major Skip
Old Mar 31, 2005 | 05:25 AM
93LT1BIRD's Avatar
Angry Need Help Major Skip
Well this was stupid on my part, but its been done and now i can't change what happened. Well I still smoked the stang. Ok here goes I was at the track the other night and as i was shifting from 2nd to 3rd i shoved it into 1st instead. Now I have a major skip at around 4 grand and above. I have had the tranny check and I have been told its not the tranny. So does anyone know what the problem might be. The oil pressure is fine holding good pressure as normal. The engine has only about 8,000 miles on it
Old Mar 31, 2005 | 06:42 AM
IslandZ's Avatar
Re: Need Help Major Skip
My fiance did that once in my car, before I did the cam, when I checked I had 1 bent pushrod (very slight bend).
Old Mar 31, 2005 | 06:46 AM
93LT1BIRD's Avatar
Ok i dont know anything about the push rods. I did pull the covers off. I can move all but one push rod slightly. I have one push rod that i cant move at all with my fingers. Could this be the one?
Old Mar 31, 2005 | 08:45 AM
You have to pull all the pushrods out to check them for straightness. Rolling them on a piece of glass seems to be the accepted test.
David Dempsey
Mar 12, 2016 12:42 AM
marlar98
Sep 19, 2015 07:53 AM
mlopezart
Sep 8, 2015 12:15 PM
ZXXVIII
Sep 1, 2015 10:13 PM
WPHIG2
Aug 27, 2015 06:37 AM
