Wheres best place to mount MSD 6AL inside car?
Old Apr 1, 2005 | 01:09 PM
trans9_5am's Avatar
Want to mount my MSD box inside car particularly on the firewall some place. I have pretty much stock interior so it looks pretty cramped under there. Has anyone done this and where did you mount it if so? Pics would be appreciated. Do you think the unit will ever get too hot inside the car? i figure it will be cooler than under the hood. Either way its probably going in the car. Thanks
Brandon
Old Apr 1, 2005 | 01:16 PM
1-bad-z28's Avatar
Re: Wheres best place to mount MSD 6AL inside car?
glove box...but i would put it under the hood. The heat won't hurt it (as long as you don't bolt it to the headers).
Old Apr 1, 2005 | 01:22 PM
Kraest's Avatar
Retired
I mounted mine right next to my CAI kit when I had it.
Mike
trans9_5am's Avatar
Had it under the hood mounted to the firewall and went bad after a year and less than 5K. It is not going near the front of the car because i dont want it up there so i say the inside would be ideal for me. Anyone that has done this?
Brandon
Old Apr 1, 2005 | 01:55 PM
It needs a ventilated place, so don't put it in the glovebox. Most people find a place in the engine compartment.
Old Apr 1, 2005 | 01:59 PM
1-bad-z28's Avatar
why does it need to be ventilated?
Old Apr 1, 2005 | 03:24 PM
93redbird's Avatar
right by the fuse box. Pick up the fuel rails OR... Put it under the hood latch.
Tim
Old Apr 1, 2005 | 03:46 PM
ManicHaze's Avatar
yeah, put it right next to the fusebox, well behind the fusebox towards the passenger compartment on the shock tower well.
here is a link: http://www.gmhightechperformance.com...1htp_ignition/ that might help you out. good luck.
Old Apr 1, 2005 | 08:24 PM
Jameslt1TA's Avatar
Take out the passenger air bag and make the cover on the dash so that it opens and mount it in there...thats what i plan on doing. Not sure if there will be enough ventilation, but i have seen other people mount theres in compartments in the dash.
Old Apr 1, 2005 | 08:32 PM
93redbird's Avatar
Yes spend a whole day routing wires there and remove a safety feature on a daily driven car. Dont keep it in the engine compartment where it should be.
Tim
Old Apr 1, 2005 | 09:08 PM
Jameslt1TA's Avatar
Tim
Some people like a cleaner engine bay. Ive seen lots of people mount theres under/in the dash. And he doesn't drive his car daily...i do and i dont have airbags. Only time i got in a wreck with a car that had airbags, the wreck wasn't to bad and the airbags burned my gf's neck and my arm.
Old Apr 1, 2005 | 09:14 PM
Because MSD says so. The electronics generate heat.
They also specifically state in their instructions to not install it in the glove box.
The MSD can be mounted in most positions, except directly upside down (if upside down,
moisture or water cannot escape). It can be mounted in the engine compartment as long
as it is away from direct engine heat sources. It is not recommended to mount the unit in an
enclosed area such as the glovebox.
Old Apr 2, 2005 | 11:29 AM
trans9_5am's Avatar
A small electronic fan should take care of any heat generated from the box.
Brandon
mr28
Apr 20, 2016 05:44 PM
thenewkid
Nov 27, 2014 09:41 AM
USAirman93
Nov 24, 2014 03:37 PM
mr28
Nov 23, 2014 11:11 AM
supercharged94Z28
Feb 24, 2003 10:22 PM
