Please help ASAP! High rpm miss?
Old Mar 29, 2005 | 09:13 PM
Nick-LT1's Avatar
My car has new plugs and wires new coil wire none of my wires are burnt but at around 5000 rpm and high i have like a studder. my car went a 13.5 last week and tonight it ran a 13.8 same track conditions but my car studder and at high rpm in every gear. What could this be? Could this be my coil? If it is should i get the MSD one? my car has 73,000 miles and i am HOPEING this is not my opti! thanks
Old Mar 31, 2005 | 09:27 PM
Nick-LT1's Avatar
Re: Please help ASAP! High rpm miss?
ttt
Old Apr 1, 2005 | 09:18 AM
Z28WannaB's Avatar
Just replace your coil and coil module, they the coil is like 15.99 from Autozone, and I think the coil module is the same price.
It will definitely help you narrow down the problem. As far as ignition goes it really can only be coil, coil wire, coil module, opti, plugs, and plug wires. Just replace everything start with coil, and coil module, then plugs and wires. Then opti.
lt1matt
Mar 21, 2015 07:35 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
DetroitZ28
Feb 13, 2015 07:33 AM
Brake_L8
Jan 20, 2015 09:44 AM
sleeperZ96BT
Jun 5, 2005 09:33 PM
