stock or hp fuel pump?
Old Mar 31, 2005 | 12:23 AM
96SilverZ's Avatar
Post stock or hp fuel pump?
I think my stock fuel pump is going bad. Should I replace it with a stock one or do I need a 255 lb pump? I think I'm making around 350- 360 rwhp.
Matt
Old Mar 31, 2005 | 01:16 AM
CamaroBoy96Z28's Avatar
Re: stock or hp fuel pump?
Not a bad idea goin with Racetronix's 255 lph system. Why not replace stock with better?
Old Mar 31, 2005 | 10:31 AM
96SilverZ's Avatar
yeah, that's the one I was thinking about. I was just wondering if I really needed that much pump?
Matt
Old Mar 31, 2005 | 10:49 AM
1-bad-z28's Avatar
It won't effect anything putting one on a stock motor much less yours. You could only benefit from it. I think that one is cheaper than a stock one anyways. I have had mine in for about 3 years and it works perfect.
Old Mar 31, 2005 | 12:23 PM
96SilverZ's Avatar
do you think I should get the whole racetronix kit or pump only?
Old Mar 31, 2005 | 12:30 PM
Pasky's Avatar
I use just the pump, the harness isn't necessary although I cannot talk because i've never used it, but I do have a walbro 255 lph and im running stock thirdgen wiring and my fuel pressure and voltage is just dandy.
Old Mar 31, 2005 | 01:50 PM
1-bad-z28's Avatar
i got the whole kit and it seems to work really good. It is very simple to install
Old Mar 31, 2005 | 02:08 PM
Z95m6's Avatar
With my stock fuel pump still on my car i added just the harness alone and my charging gauge went up at least 1 full volt. I personally suggest you run the harness. The whole setup isn't that expensive and it just plugs right in and fits perfectly. A to Racetronix.
Old Mar 31, 2005 | 02:11 PM
DemonZ28LT1's Avatar
Is the Inline Mallory Comp Series 110 Fuel Pump any good? Anyone know the specs on it?
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
