need help with oil pump shaft install
Old Mar 31, 2005 | 09:36 PM
JD95BIRD's Avatar
Hey all, I need to install a new oil pump shaft in my firebird, and have a few questions. First off I installed the new oil pump and shaft when the engine was out, but I forgot to put the little "sleeve" at the base of the shaft where it goes to the oil pump. Well the engine is in the car now and I was just wondering, If I just pulled the intake off and took out the pump gear that goes where the dist normally goes, could I just install a new shaft like that? I want to get the arp oil pump shaft and it already has the sleeve on it. Will I just be able to drop it down in there and it will work or is there a problem I'm not seeing. I don't really want to pull the motor again but if thats best I will. Just trying to save some time since summers comming up fast Anywho sorry bout the long post just want to get this right.
Thanks all
Later
Josh
Old Mar 31, 2005 | 09:55 PM
Re: need help with oil pump shaft install
I am not sure the oil pump shaft sleeve will fit down through the hole.
Old Mar 31, 2005 | 10:21 PM
JD95BIRD's Avatar
Assuming that the sleeve will fit would there be any other problems? And if it wont is there any other way to do it without pulling the motor? Like I said If I have to I will.
Thanks for the fast response btw.
Josh
Old Mar 31, 2005 | 10:35 PM
As long as everything is engaged properly, there should not be a problem.
Old Mar 31, 2005 | 10:58 PM
JD95BIRD's Avatar
Well I'll give it a shot and we'll see what happens,hopefully for the good
Old Apr 1, 2005 | 07:41 AM
EviLZ28's Avatar
You will not be able to slide the Arp shaft through the top as the collar that goes around the oil pump shaft will not fit through the hole. It must be installed from the bottom.
Old Apr 1, 2005 | 08:40 AM
JD95BIRD's Avatar
Well that sux I guess I should learn my lesson from this, pay more attention Thanks for the help guys!
Old Apr 1, 2005 | 09:41 AM
turbo_Z's Avatar
Melling makes a shaft with a built-in collar so you dont risk that plastic piece breaking. It all metal and all 1 piece.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
squarehead
Nov 21, 2014 08:02 PM
