is this true
Old Mar 29, 2005 | 05:36 PM
britts85's Avatar
is this true
So I was told that if you have a little bit of an oil leak like a rear main seal that has a minor drip. that If you go to a thicker oil it stop's the leak, or just slow's it down. I've never heard of this, Has anyone else ever heard of this?
Old Mar 29, 2005 | 06:06 PM
93redbird's Avatar
Re: is this true
yes. use valvoline max life oil. It will condition(swell) up the seals on the gaskets. now I am not sure since the seals are not necessarily rubber on the front and rear main.
Old Mar 29, 2005 | 06:10 PM
MEAN LT1's Avatar
Re: is this true
Fix the leak.
Old Mar 29, 2005 | 06:13 PM
disco192's Avatar
Re: is this true
If its an M6, then you will be VERY sorry that you put it off when you have to replace a clutch.
Old Mar 30, 2005 | 07:13 AM
britts85's Avatar
Re: is this true
It isn't an issue for me right now. It was just something I heard and was wantin my imput on it.
RUENUF
Mar 13, 2016 03:37 PM
generaldave
Sep 25, 2015 06:48 PM
Slayer
Aug 17, 2015 03:55 PM
meissen
Aug 11, 2015 06:05 AM
