What clamshell bolts For poly Motor Mount
Well i got poly mounts and they came with bolts to replace the rivets on the driver side but not the pass side.. So what bolts did you guys use to hold clamshell together that dont rub the k member
Re: What clamshell bolts For poly Motor Mount
I cant remeber exactly, but didnt one of them come with some zip ties, just to hold it together, and then the bolts that either mount it to the frame or the block clamp it together for good, cant remeber how i did mine but i know there was something "weird" going on.
Quick question for all you guys. i bought a used set of poly mounts and they look and feel the same as stock. Are your poly mounts stiffer to the touch?
