RKSport Header flange bolt holes
Old Mar 31, 2005 | 09:47 AM
RichWhalen's Avatar
I'm replacing my edelbrock TES headers with a set of RKsport headers and the install has been brutal. I can install my edelbrocks in about 2 hours - I worked last night for 8 hours and only got one header installed. The problem that I'm having is that I cannot get the bolts started. I hand to use my grinder on the holes in the flange in order to install the driver side header. I did a little grinding on the passenger side until my air grinder died. I can get 4 of the 6 bolts started on that header. The last 2 will not go in. I tried pulling the header as far away from the head as possible and even chased the threads.
It seems that the holes are not located correctly on the flange. Has anybody else had this problem with Rksport headers? I'm off to buy another grinder to get these damn things installed.
Victor Lamb
Aug 26, 2017 02:52 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Joes96z
Dec 13, 2014 07:48 PM
Azimiut
Jul 22, 2002 05:47 PM
