Is this package safe for a car with 110k
Old Mar 30, 2005 | 09:53 PM
9T4Z28's Avatar
Im looking into saving up for a mild streetable cam, jet hot longtubes, and ported and polishing my stock heads, then finish it off with a tune from madz28.com. What else am i missing, and how much rwhp and 1/4 mile times should i expect out of this package? Im not really swimming in the money so buying AFR heads or aftermarket ones are kind of out of the question. And is it possible i could really mess up my engine it has 110k on it but i have had no mechanical problems yet, just the usual opti and maf stuff. Thanks guys i appreciate it, and what kind of streetable cam should i look into?
THANKS!
Old Mar 30, 2005 | 09:58 PM
ajschult's Avatar
Re: Is this package safe for a car with 110k
www.eportworks.com for a streetable h/c package that wont break the bank. Keep in mind all the little costs if money is an issue: gaskets, plugs, wires, roller rockers, lifters, pushrods. I just went with the LE3 package, and when all was said and done I was over 3k with all the necessary parts. Make sure not to get coolant on your opti as well, you do not want to have to replace that pile of monkey ****.
Old Mar 30, 2005 | 10:11 PM
9T4Z28's Avatar
LOL i just replaced my wires and plugs, and my dad replaced my thermo, and he sprayed collant all over and some got on to the opti b4 the wires and plugs installation. I was about to break down, I just replaced my opti last october. I know the whole feeling about this stupid enginering flaw. Thanks for the site.
Old Mar 30, 2005 | 10:14 PM
9T4Z28's Avatar
With the LE1 package do you think it will push my 110K motor over the edge?
And how much hp would i be loosing if i didnt use 30 pounders and the 52 MM tb? Or will it not work right?
Old Mar 30, 2005 | 10:19 PM
WeirdRich's Avatar
I just spun the rod bearings on my 94 Z28 with 93k on the stock engine. I bought the car at 90k though so who knows what the previosu owner did to it... It all depends on how hard the car has been driven in the past. If it wasnt beat to hell, then you should be fine.
Old Mar 30, 2005 | 10:21 PM
9T4Z28's Avatar
Then i think im out of luck, becuase i know the previous owner used NOS on it... Man this sucks,, if a bearing is messed up how much is that to fix?
Old Mar 30, 2005 | 10:57 PM
WeirdRich's Avatar
which bearing? theres a few on the LT1, lol
spun rod bearings require the engine to be pulled and rebuilt...so LOTS of money in parts and even more if you can't do the work yourself.
Im taking the opportunity to build a 383 stroker
Old Mar 30, 2005 | 11:00 PM
9T4Z28's Avatar
Yea im so stuck i really wouldnt be able to afford a rebuild with my budget, if anything did happen.. DILLEMA... i hate this lol i want more power, but i dont want a huge headache along with it, damn it sucks to be 19 and not having a great money supply.
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
USAirman93
Nov 24, 2014 03:37 PM
Queens94z28
Nov 20, 2014 06:03 PM
