Fuel question
Old Mar 29, 2005 | 09:30 AM
joshp007's Avatar
Fuel question
I am putting p&p heads, cc306, roller rockers, p&p intake, 58mm throttle body on a 383 lower end. Will I need larger injectors and possibly a inline fuel pump?
Old Mar 29, 2005 | 10:24 AM
formula69's Avatar
Re: Fuel question
get a 255 intank pump and some 30lb injectors to put it on the safe side
Old Mar 29, 2005 | 01:09 PM
Chris 96 WS6's Avatar
Re: Fuel question
Agreed. No way the stock injectors are going to be able to keep up with that, or the stock pump for that matter.
Look at the Racetronix plug-n-play kit with the Walbro pump, can't go wrong there.
Old Mar 29, 2005 | 01:42 PM
sssalah's Avatar
Re: Fuel question
Theoretically the 30lb injectors are good to about 384 fwhp at 0.5 bsfc and 80% ds. Your setup is surely producing more than that. Go with at least 36lb, can get 460 hp at same conditions.
Old Mar 30, 2005 | 10:28 AM
joshp007's Avatar
Re: Fuel question
Hey guys thanks for the replies. I am glad I asked this question before I installed my motor Thanks again
Old Apr 17, 2005 | 10:42 PM
joshp007's Avatar
Re: Fuel question
Would 30lb be ok if I went with just a 355 bottom end?
Deadbolt24
Jan 19, 2015 01:29 PM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
guionM
9
Aug 29, 2002 01:48 PM
dansam
Jul 20, 2002 01:10 PM
