Wrong Comp Cam Pushrods?
Old Mar 30, 2005 | 09:52 PM
Bersaglieri's Avatar
I went to Summit to get some Comp Cam hardened pushrods for my 1.6 RR install. I thought I had the right part number 7808-16, but he said they were listed for non-LT1 cars.
I got him to look up the length which is 7.195. I have since found that the 7808-16's at Thunder are 7.200.
Will these still work and if so do I have to do anything special to accomodate them? I bought them anyways, but can return them.
My setup is going to be 1.6 Pro Mags NSA 7/16 with GM guideplates and ARP 7/16 studs and hopefully these pushrods on a stock cam and lifters. Thanks.
-Dustin-
Old Mar 30, 2005 | 10:59 PM
SStrokerAce's Avatar
Re: Wrong Comp Cam Pushrods?
They will work most likely, but I'd go to a better PR than the High Energy line, more like a Magnum or Hi Tech 5/16 PR.
Bret
Old Mar 30, 2005 | 11:03 PM
Well until I do a heads and cam will they hold me over? I was pretty sure my stockers are hardened, but wanted the extra insurance with the guideplates until I did a H/C package.
Thanks SS, funny thing is they are the same part number and Summit said they are specifically not for LT1's. They guy almost wouldnt let me buy them. It's listed in the computer as "Do not sell for use in LT1's"
Do you think they are the same thing just listed 5 thousandths off?
-Dustin-
Old Mar 30, 2005 | 11:26 PM
What's your Rockers and Guideplates deal?
I don't see a huge issue with them in a LT1 over another HR SBC.
Bret
Old Mar 30, 2005 | 11:31 PM
Bret
Deal? I dont follow, but I have Gm Guideplates to be used with my NSA Pro Mags.
Thanks.
-Dustin-
Will84's Avatar
I would go with hardened chromoly from thunder... 7.2"
Old Mar 30, 2005 | 11:40 PM
For now I am just sticking with the Hi-Tech Comp ones, I just want to make sure the length is good, thanks.
-Dustin-
Old Mar 31, 2005 | 12:35 AM
Looks like you are good with guideplates and rockers....
I'd get Hi Techs so later on when you do a cam you are set.
Good luck
Bret
Old Mar 31, 2005 | 06:18 PM
Thats my plan, doing a bit beefier pushrods and R lifters when the cam goes in. But until then I think I'll be ok, just looking for some extra power without opening her up too much. Thanks again.
I'd still like to know what they are listed under the same part number with different listed lengths. I'll have to call Comp Cams tomorrow and ask.
-Dustin-
Old Mar 31, 2005 | 09:35 PM
Bud M's Avatar
I wouldn't think .005" difference in pushrod length would be a problem, would it?
Old Mar 31, 2005 | 10:41 PM
I hope it doesnt make a difference. The main consensus is that it wont matter and the part numbers match up so I just think that someone has been rounding it up or something. I'll call Lloyd tomorrow for additional verification. The only thing that bugs me is I find conflicting stock pushrod lengths in my searches.
-Dustin-
Old Mar 31, 2005 | 11:21 PM
sssalah's Avatar
These are the correct length pushrods, I've ordered 3 sets for friends LT1's and 2 of the 3 are working, the third set is all bent (he over reved it in the burnout). Far as I know comp has pushrods in the 0.05" incremint, so you'll get ...7.15, 7.2, 7.25....
Old Apr 1, 2005 | 09:48 AM
Thanks guys for the input. I am going to call Comp Cam to ask why the two places have conflicts on the length.
-Dustin-
Old Apr 1, 2005 | 10:39 AM
BUBBA's Avatar
Geometry, Geometry, Geometry: If in doubt, get an adjustable push rod and determine the exact length needed. Possible cause of my valve train going to hell having bought +.050 push rods, i.e., 7.250s instead of stock length.
No one, not even mechanic advised me to go with the proven length.
Advise that you do so or face the consequences. JMHO
Old Apr 1, 2005 | 11:57 AM
stereomandan's Avatar
Those are the pushrods that I used as well. They are the stock 7.200" length, and correct for the application. After installing them, I looked to see if the rocker tip was centered on the valve tip, and everything lined up good from closed valve all the way to open valve.
It's funny though, because when I took my old pushrods out and stood them up next to the 7808-16's, the Comp Pushrods were slightly longer, maybe 0.025". After looking at the stock pushrods, it looked like the difference in height was just due to the end of the stock pushrod getting polished and a little worn after 69k miles. I have had it all back together and running with the new valvetrain for about 600 miles, and around 10 runs up to 6000 rpm and everything is great.
Dan
