spark plug not getting enough spark from wire?
Old Apr 1, 2005 | 05:56 PM
formula69's Avatar
i replaced my burnt wire with one of those msd replacement kits.. it didnt have all the right fittings so i just used the opti connection from the bad wire and put it on the new wire.. i think i screwed up installing this because my car still feels like its running on 7 cylinders... under very very light pedal pressure, it revvs and sounds normal. but under any acceleration over very light it starts to drag *** and feel just like if you disconnected a spark plug.. im thinking maybe i messed up on the wire end swap and its getting some spark but not full spark
heres how i troubleshot the problem... i turned the car on with all connections made.. gave it a few revs and noted how it ran. then i took the wire i presumed to be not getting full spark off, turned the car on and gave it a few revvs... both runs had the same problems of running like a dog but with the wire connected it wasnt quite as bad. next im gonna pull a random spark plug off and see what happens any suggestions?
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
greenzee28
Mar 26, 2015 09:13 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
