Losing power up top?
Old Mar 31, 2005 | 09:25 PM
ChrisUlrich's Avatar
I got a cam, but no headers... I think this is maybe because of the choking exhaust and hoping its nothing else. Anyone else ever do this? Cam THEN headers?
Old Apr 3, 2005 | 09:38 PM
Re: Losing power up top?
No one?
Old Apr 4, 2005 | 12:44 AM
chrism400's Avatar
Chris, did you get new valve springs? Are your rockers set too tight maybe? Did you get a tune for the new set up?
Old Apr 4, 2005 | 01:02 PM
Got new valve springs, rockers to tight... wouldn't tight rockers knock against the valve covers? I dynoed 302rwhp pulling to 5450... never got a chance to do a pull to 6k... hrm
got a tune from Ion
Old Apr 4, 2005 | 01:16 PM
MeanGreen97Z's Avatar
When I was taking my car back to stock I put stock manifolds back on my car and stock exhaust. The hot cam didnt pull much past 5500. Maybe none at all.
Old Apr 4, 2005 | 01:34 PM
wb3s94z28's Avatar
I'm running P&P heads w/ the LT4 hot cam and stock manifolds and my power feels EXTREMELY LOW. Like almost stock low. I spent all my money on the internals so i couldn't afford headers, i think that it's slowing me down BIG TIME, i have yet to prove it though.
Old Apr 4, 2005 | 02:49 PM
TransAm2k4's Avatar
i'm having a similar problem but i have a cc306 cam with AFR heads and LT pacesetters.
Old Apr 4, 2005 | 03:04 PM
I bet it is! LOL
Old Apr 4, 2005 | 03:06 PM
Possible the valve springs are worn out? How old are they?
Old Apr 4, 2005 | 10:21 PM
chrism400's Avatar
Clogged cat? Fuel pressure ok? Any codes?
Old Apr 4, 2005 | 10:36 PM
Z95m6's Avatar
Its your manifolds. You are probably right on par for a car with just a cam and no headers. I would say with that cam probably you should put out about 340 rwhp if you had headers. People with stock cars have gained 20rwhp with headers i would say adding a cam makes headers that much more important probably to the tune of 30rwhp or so. You won't believe how much headers helps a stock LT1 breathe up top let alone a cammed one.
Old Apr 4, 2005 | 10:37 PM
Robs97Z28's Avatar
what is the best way to check for a clogged cat?
Old Apr 4, 2005 | 10:55 PM
Thats what I thought...
I only trapped 104 with this setup, but I could only rev to like 5500... my tach was a lot farther off then I thought... :-/
Think revving to 6k would improve my trap at all?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
eanhl2004
Apr 4, 2015 12:01 PM
siguy
Nov 27, 2014 10:07 AM
RedLineRev
Jan 23, 2003 03:51 PM
