PTK 355 LT1 Turbo car with AI Advanced Induction heads
Old Mar 30, 2005 | 01:00 PM
JZ 97 SS 1500's Avatar
Well for the folks that have called on the engine specs for this car...here they are...
355 LT1
2 bolt block-4 bolt splayed conversion
Eagle crank
Eagle rods with ARP bolt upgrade
JE pistons
custom turbo cam 218/218 .544/.544 with 114LS
Advanced Induction LT1 fully ported heads
Advanced Induction LT1 ported intake
The car made 1012rwhp/909rwtq with the T88 and 24psi, and 987rwhp/922rwtq with the 76GTS all through the 6spd tranny from D&D.
http://forcedinductions.com/images/timeslip.jpg
Jose
Old Mar 30, 2005 | 01:52 PM
tireburnin's Avatar
Re: PTK 355 LT1 Turbo car with AI Advanced Induction heads
I'm sure that power is all from the head porting .
Bad *** setup...maybe when I'm done with this DP nitrous stuff I'll try a PTK setup out. With numbers like that, it sure is tempting.
Old Mar 30, 2005 | 01:57 PM
lt4 fd's Avatar
what kind of fuel did you use? Also what ECM did you use, im assuming aftermarket...?
Old Mar 30, 2005 | 01:58 PM
Well the heads do make a difference. With the other heads on the car the #'s put down would have required a higher boost setting, which of course causes more hidden problems.
Jose
Old Mar 30, 2005 | 02:00 PM
Its is race fuel indeed, and the ECM is a DFI Gen 6.
More on the car can be found here...
http://forcedinductions.com/ipw-web/...topic.php?t=74
Jose
Old Mar 30, 2005 | 02:01 PM
tireburnin's Avatar
I was just poking at other members of the board (see sig.)
That is a BADASS car, no ifs and or buts about it.
Old Mar 30, 2005 | 02:04 PM
Pasky's Avatar
Those are damn nice numbers! I always thought you wanted more exhaust lift and duration with a turbo motor though.
Old Mar 30, 2005 | 02:05 PM
Your car looks nice dude, except for the freeway pics.....off roading with F-body's doesn't work to well...hehe
Jose
Old Mar 30, 2005 | 02:06 PM
Pasky it all depends on the turbo setup. Typically you run less duration on the exhaust then the intake on a turbo setup. On a blower setup its different. Also it will depend on whether its a log style system or header system.
Jose
Old Mar 30, 2005 | 02:07 PM
AiSr's Avatar
It'll definitely be interesting to see how the car runs with the chassis sorted out, especially at full weight .
Perhaps this car would be a good candidate to try out one of the forced induction specific TFS based offerings we're still testing/developing? Next time you and I or you and Ron speak, mention that if we don't.
Good luck & take care,
-Phil
Old Mar 30, 2005 | 02:55 PM
Phil we may talk soon about that. Will depend on what the customer wants to do next. I believe he plans to up the boost more right now. Not sure how much more the T88 can flow out though.
Jose
Old Mar 30, 2005 | 03:06 PM
atljar's Avatar
Jose-
What does a turbo setup like that cost inlcuding all the little stuff, bov, intercooler, oil lines, clamps etc (nothing engine/head related, nothing fuel). Just looking for a rough estimate.
-Jared
Old Mar 30, 2005 | 03:21 PM
Our LT1 with the base system T70 (850hp) is $5199. Its comes with an Air to Air intercooler and is complete with everything from A to Z to bolt in and go. We also make a non-intercooled version with the T70 and its $3999. Right now we have a $400 dollar off sale till Friday on all our complete systems.
Here are some of the specs....
Dual 4 into 1 Headers in 1 3/4"
2.5" Crossover with Flex section
3" Downpipe
TiAL Billet Wastegate
3 core Air-to-Liquid Intercooler (1300hp), or Air-to-Air Intercooler(1000hp)
Water tank for Intercooler system
Teel Water Pump
Water Lines & Fittings
Replacement Spal Fans
All silicone hoses and oil lines
V-Band Clamps & Ball Joints for LEAK FREE operation
Old Mar 30, 2005 | 06:25 PM
atljar's Avatar
Thanks. Not doing anything this year, but my motor is big boost ready with just a piston swap
Old Mar 30, 2005 | 07:17 PM
SS MPSTR's Avatar
Mine too. Jose, we will be talking sometime next year
