What plugs for cc306 Cam
Old Mar 31, 2005 | 12:36 PM
93transam1234's Avatar
I had the TR 55's (i think) and was getting a studder at 5500 - 6000 rpm's.
Was thinking it was a fuel problem at first but it seams that the stock Inj. are doing ok for now and my fuel presure doesnt surge at all at WOT
So someone said maybe i needed difrent plugs for the cam..I duno what do u guys think?
Old Mar 31, 2005 | 01:24 PM
fesgali's Avatar
Re: What plugs for cc306 Cam
not sure about a different type of plug but possibly a colder setting, maybe gapped at .035-.045
Old Mar 31, 2005 | 03:38 PM
hot_red_z28's Avatar
i highly doubt the problem is your plugs... many people run the tr55's with a variety of different head/cam combos... you could try making the gap a tad smaller, but I doubt that is the problem...
If you just installed a cam, you may want to check the opti...
If you swapped to vented opti, make sure the dowel pin length is correct on the new cam... if it is too long it'll damage the opti...
if the plugs or wires are kinda old, it may be time for a tune up...
could also be a faulty ignition module, etc...
and the last thing I can think of off the top of my head is the pcm rev limiter...
sometimes the dash tac is not always accurate... once I hooked up my digital ignition I noticed my tac was off by almost 200rpms... and the stock rev limit is just a bit under 6k i believe...
-Garrett
armedtrigger
Feb 24, 2015 08:30 PM
StansZ28
Feb 19, 2015 07:39 AM
Amshnock
14
Jan 18, 2015 11:47 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
GigaMp3z
Feb 20, 2003 02:57 PM
