spring retainers for 918's
Old Apr 1, 2005 | 02:03 PM
1-bad-z28's Avatar
What retainers and locks are needed for the 918's? Steel, not titanium.
Old Apr 1, 2005 | 05:16 PM
NVRLATE's Avatar
Re: spring retainers for 918's
I'm in the process of installing 918's on my car. I'm using comp cam retainer part number CC-795-16 and comp cam 10 degree locks part number 613-16.
Old Apr 1, 2005 | 06:42 PM
Camaro4LifeSS's Avatar
I'm in the process of ordering mine as well only I ordered the 611-16 locks.Whats the difference in the ones I ordered and the 613-16 locks.I saw that it said the 613-16's are without recess for lash cap.The ones I ordered (611-16) are with recess for lash cap.What does this mean and do I need to call and change my order?
Thanks,
JE
Old Apr 1, 2005 | 09:49 PM
NVRLATE's Avatar
Thanks,
JE
I'm not sure what that means. I called comp cams. Told them what retainer and springs I was using and asked them what locks I needed and that's what I ordered.
Old Apr 1, 2005 | 10:25 PM
raroz28's Avatar
947 steel retainers is what i'm using with my 978 springs and 611 locks.
Old Apr 1, 2005 | 11:40 PM
sssalah's Avatar
The lash caps as I understand it are used for solid cams applications were there is clearence between rocker and valve tip and it's used to reduce the wear on the valve tip. With hydraulic cams there's no lash. The locks lockes with the lash cap recess will work, but you wont be putting any cap in that recess.
The 918 are known as behive springs that require vrey small special retainers, the 978 are regular springs, completely different.
Old Apr 1, 2005 | 11:52 PM
I wonder about Comp's tech line sometimes.When I first called they said 918 spring with 795 retainers.Then I called back a week or so later and they told me 787 retainers with the 918 spring.So I decided to go with 10 deg locks and retainers(795) and they told me the locks I needed are the 611's.I don't know man,I think every person who answers the phone there has a different opinion about what you should get.
So my 611 locks will work with my 795 retainers I ordered?I hope so cause I done ordered?
Thanks,
JE
Old Apr 2, 2005 | 03:04 AM
95PoloVert's Avatar
The 787's will also work, along with 648 locks. It's just a 7 degree setup vs. 10.
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
R@mpage
Apr 20, 2015 10:02 AM
QuickSilver02
Apr 7, 2015 11:12 AM
lt1car
Sep 12, 2002 09:05 PM
