How can I figure out what size my Aftermarket TB is
Re: How can I figure out what size my Aftermarket TB is
You could measure the diameter of the openings
25.4mm/inch if you don't have a mm ruler.
Also, if you have it off look at your intake. Most intake port jobs it is "obvious" they have been ported because normally a Dremel or similar hand held tool is used. The stock openings are 52mm. If yours have been bored larger for the throttle body, chances are it's a 58mm tb. If the intake holes are nice and perfectly round and the tb mates up good then it's likely a 52mm.
However, easiest way by far is to just measure the openings (across the center).
25.4mm/inch if you don't have a mm ruler.Also, if you have it off look at your intake. Most intake port jobs it is "obvious" they have been ported because normally a Dremel or similar hand held tool is used. The stock openings are 52mm. If yours have been bored larger for the throttle body, chances are it's a 58mm tb. If the intake holes are nice and perfectly round and the tb mates up good then it's likely a 52mm.
IgorT.455/406
Mar 12, 2015 03:39 AM
heavenly_six
Dec 10, 2014 12:23 AM
