Belt tensioner pully, help !!
Old Apr 1, 2005 | 10:26 PM
raroz28's Avatar
The belt pulley to the left of the crank. I took off the pulley, then I took out the allen screw under it. It popped out and there was this big spring. Now I can't get it back on the right way. What did I do, and how do I fix it??
Old Apr 1, 2005 | 10:27 PM
raroz28's Avatar
Re: Belt tensioner pully, help !!
I mean, I can get it in, it's just off... Like the threads for the pulley are too far down.
Old Apr 1, 2005 | 11:28 PM
sssalah's Avatar
Why did you remove it like that, you know that it's supposed to come out by removing the 2 M8 bolts that holds it to the accesory bracket. Remove those bolts with a 10mm wrench or socket and try to fix every thing back in the housing outside the car. That spring should be under good preload. Consider that this piece is around $30 so you might not want to waste more time or injuring yourself strugling with it.
Good luck
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
colts0455
Jul 7, 2015 07:19 PM
