CONSTANT TPS Problems!
Old Mar 29, 2005 | 12:48 AM
Munson's Avatar
Alright, ever since i got my as&m 54mm throttle body my car has been acting funny. Every now and then when i floor it or give it about 3/4 pedal the car will rev up and then shift into OD. After this the car starts running shaky and just not right.. It did it when the car was stock and just the TB and now it still does it with the h/c setup. The computer kept sending me a tps code saying falty wiring or bad sensor. So I replaced the sensor and im still having this problem. It is fixed when i reset the code by disconnecting the battery. Any suggestions?
Old Mar 29, 2005 | 03:21 AM
Zeueses 97 RamAir's Avatar
Re: CONSTANT TPS Problems!
You have to modify the tps where you screw it in drill the hole bigger at wot it should read above 4.3 volts if it dos not the ses light will come on
Old Mar 29, 2005 | 01:03 PM
Munson's Avatar
well hopefully thats the problem. unfortunately i dont have any tools to monitor the voltage to the tps. What can i buy for cheap to do this?
Old Mar 29, 2005 | 01:43 PM
Blownbird355's Avatar
Find a board member to let you hook their Datamaster or similar tool and turn key on but dont start. Datamaster gives a number reading I think 99 is maxed when wot. Sometimes it will go back to 1 and you will get the probs you described. Other scanners may give voltage readings make sure that it reads linear as you move pedal. And try to find out the voltage window. (Edit) Just read yours is 96 so Datamaster wont work bud an OBD2 scanner should work. Should be min or max reading for voltage.
Anyone know if the scanners Autozone uses will do this???
Old Mar 29, 2005 | 01:52 PM
All you need to check the TPS voltage is a simple volt meter.... the kind you get in the $20 multi-meters. Alternatively, any good OBD-II scanner or scan software will check it.
The PCM checks both the closed throttle and wide open throttle voltage. If its less than 0.20V closed, you'll get P0122. If its more than 4.9V it sets code P0123. Then there's a rationality check. The PCM compares the throttle position reading to a predicted throttle reading based on engine RPM. That will set P0121. Which code did you get?
Old Mar 29, 2005 | 09:26 PM
Munson's Avatar
man i wish i could remember the code ill look around for the paper i wrote it down on but that was a few weeks ago.. If it goes off again ill check it and pm you
timmy39120
May 8, 2015 11:41 AM
mattstrike
Mar 24, 2015 02:11 PM
edman
Jan 22, 2015 02:45 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
