misfire issue???
Old Mar 29, 2005 | 10:42 PM
Firebird355's Avatar
misfire issue???
OK, heres the deal... I was getting water in my oil and traced it back to what seemed to be just a head gasket.... ok got the heads checked and everything they were fine... so I threw it back together last night and this morning... ok thats not my issue..
Before I tore it apart I had developed a misfire problem once the engine warmed up... Ran just fine until the motor was at running temp for a while... I thought it was my plug wires because they were cracked and I noticed it sparking on the strut tower at one point... this is right before i tore it apart..
Ok, so I got it together tonight and decided to take it out for a drive...was acting alright... then it started misfiring again... at part throttle and maybe up to half throttle....but when I pedal it a little then lay into it stops misfiring and just takes off like it should..but it hesitates first..
It has new plugs and wires....The Opti was replaced in the Fall, I bought it used but I know for a fact it only had 3000 ish miles on it when i got it...
Another thing is fuel pump maybe? It did run out of gas on me in the garage a couple weeks ago?
Any ideas?
Sorry for dragging this out, and thanks for any help in advance!
PCLZ28
Dec 24, 2015 05:19 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
SigSauer40
Exhaust System
Apr 29, 2015 09:02 AM
Alex Barnes
Jan 24, 2015 10:21 PM
derty
Jul 16, 2002 12:20 PM
