It Cranks But Won't Start
Old Apr 2, 2005 | 04:21 PM
catwalk's Avatar
I performed the Schrader valve test as was suggested. The pump is delivering a lot of pressure. The only other possibility I could come up with is a loose timing chain. Consequently, I checked on the condition of the chain and found it to have a bit of a sag. Moreover, an inspection of the sprockets revealed some scarring, evidently from the looseness of the chain, in the grooves of the upper and lower sprockets. Could a loose timing chain be the cause of my no-start problem? Please advise.
Old Apr 2, 2005 | 04:33 PM
camarolover20's Avatar
Re: It Cranks But Won't Start
Did you already check the opti?Mine one day just stoped and I wasnt thinkin anything so I tried to restart it bc I was a lil low on gas but should of made it.So I went and got gas and put it in and the car tried to restart a lil so i changed the opti and that was it
Old Apr 2, 2005 | 04:43 PM
catwalk's Avatar
The opti was one of the first thing I checked. It's good. Also checked all injectors. Good.
Old Apr 2, 2005 | 04:47 PM
CoUnTryMuZiCZ28's Avatar
Did you check all your fuses? Injectors ETC..??
Old Apr 2, 2005 | 05:12 PM
catwalk's Avatar
The following have been checked and verified to be in working order:
-Fuel Pump (bench checked)
-Fuel fuse and relay
-Fuel injectors
-Fuel pressure
-Opti (removed and checked)
-Coil (removed and checked)
-Spark plugs
-Fire to plug
-New Fuel filter installed
I have just removed the timing chain to determine if this is the culprit. Upon inspection, it appears to have a bit more sag than I think it should. Moreover, the sprockets, upper and lower, are scared. I presume this is from the loose chain.
Old Apr 2, 2005 | 05:17 PM
I still think you blew somekind of fuse.. Even if the timing chain was sagging it would still start..
Old Apr 2, 2005 | 06:01 PM
catwalk's Avatar
I would truly like to believe that the problem is a blown fuse, inspite of the fact that I've been tearing at the car for the past 4 months trying to get at the problem. Assuming that you are correct, and I hope that you are, are there any additional fuse location apart from the fusebox under the hood and the one in the dashboard on the driver's side? The car is a '96 Caprice.
Old Apr 2, 2005 | 06:02 PM
those are the only two..
Old Apr 2, 2005 | 06:06 PM
catwalk's Avatar
At your behest, I'll re-check all fuses and relays. Thanks
Old Apr 3, 2005 | 08:04 AM
slopokrodrigez's Avatar
2 quick questions. Is the engine back together and how did you check the injectors?
Old Apr 3, 2005 | 12:28 PM
catwalk's Avatar
Right now the front of the engine is off in order to access the timing chain. As for the injectors, they were checked with one of those gizmos with contact points ( I don't know its actual name.) that is stuck into the electrical injectors connections. All 8 of them lit up. A friend of mine suggested that a stuck EGR valve could be the problem. Your thoughts...
Old Apr 3, 2005 | 04:59 PM
Let us know when you get it back together.
Old Apr 3, 2005 | 05:20 PM
93transam1234's Avatar
I had a caprice with the same problem, it ended up being one of the wires that went to the wire harness on the coil.
I have seen another caprice with the same problem
eazyZ
Mar 1, 2015 07:12 AM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
