need good crank...scat ok
Old Apr 1, 2005 | 02:05 PM
97Z-M6's Avatar
im going to hopefully hit 430 rwhp. i may wanto spray a 200 shot later later. then again i may not, but i dont want to tear it back down if i decide to. the rods are lunati and the pistions are ross. but i need to know if the scat forged crank will hold, its going to be a 355 i cant seem to find a place to buy cola cranks anymore.
any help or opinions are welcomed
Old Apr 1, 2005 | 02:24 PM
RacerTim's Avatar
Re: need good crank...scat ok
If your looking to save money and get a nice crank, loook at the factory steel ZZ4 piece.
Old Apr 1, 2005 | 02:32 PM
Pasky's Avatar
Scat 9000's are advertised to 600hp.
Oh, your going forged, should be good to go.
Old Apr 1, 2005 | 02:53 PM
97Z-M6's Avatar
joe overton did my cam. and he said i will need to shift at 7000 so ineed a crank that can take the rpms.
i just cant find cola anymore.
i have looked at scat.
how good is scats forged stuff. and what hp and rpm is it good to.
Old Apr 1, 2005 | 03:00 PM
Pasky's Avatar
No idea, try calling cnc-motorsports(.com). They have the stats for their items they carry and they carry scat 4340 forged cranks. They helped me decide on the rods I wanted.
Old Apr 1, 2005 | 03:17 PM
CMoney's Avatar
I have a brand new 3.875" Callies Dragonslayer I might be selling.
Old Apr 1, 2005 | 03:23 PM
97Z-M6's Avatar
too bad its not a 3.50 or 3.48 stroke im doing a 355
Old Apr 1, 2005 | 03:30 PM
Camaro_Guru16NY's Avatar
ive heard way to many horror stories with scat cranks but some people stand by them. the majority of them come so far out of balance that it would cost a small fortune in heavy metal to correct. im a good believer in the eagle stuff especially for the price and they are pretty stout pieces.
-john
Old Apr 1, 2005 | 03:47 PM
CMoney's Avatar
Any reason for that? The majority of people only go to a 355 to still use the stock crank. If you're buying a whole new rotating assembly, then getting a few more cubic inches is well worth it.
Old Apr 1, 2005 | 04:23 PM
97Z-M6's Avatar
i disagree. you have to look at the whole picture. a set of stock ported heads will not support a 383 ,(the way it should run anyway) do a search and look at the rwhp betwwen a 383 and a 355. a the 383 are making about 10 more hp (using stock ported heads) thats it. the cost isnt much for a 383. but sense joe overton told me this motor should make 450 rwhp, i think ill go 355.
but i was going to use a stock crank a nd i have one. but i may spray it later and to be totaly honest with you, i probably wont. but if i decide to, i want to be able to. i may only be a 150 shot but who knows
and cmotorsports no longer sell scat, but they do sell eagle.
Old Apr 1, 2005 | 04:46 PM
97Z-M6's Avatar
heres what i found on gmpartsdirect i wonder if this crank shaft will work.
but it says forged 1053 ???
http://www.gmpartsdirect.com/results.cfm
then heres colas site
http://www.colaperformance.com/main.php?stm=PROD_TALL
Old Apr 1, 2005 | 04:47 PM
I have to disagree tho, Alot of people really overlook the potential of LT1 castings. If they are worked over correctly and matched to the correct valvetrain then they are capable of producing very good numbers. Ive been talking alot with Bret Baur on my set up that Im putting together this summer 383, LE3 LT1 castings, 12:1 compression, Single Plane intake, custom HR grind cam and carb, and he feels that my goal of 500 rwhp is well attainable. with a good tune.
-john
Old Apr 1, 2005 | 04:51 PM
97Z-M6's Avatar
im talking about stock intake not carbed yeah that way maybe. thats a different route than im going.
Old Apr 1, 2005 | 11:55 PM
Mindgame's Avatar
-john
Hmm, I've heard and experienced pretty much the opposite.
IMO, Scat is the best of the import stuff.
Back to cranks for this build. I'd step away from the 1053, only settling for a 4340 forging. When you consider the cost, there's just no reason not to go with the stronger crank.
On that matter, Scat makes everything from inexpensive 4340 forgings to lightweight/contoured/slicked-out billet cranks.
HTH (Hank the Crank... been around since dirt) also makes a very nice forging for an equally nice price. Have used HTH stuff in a number of builds.
-Mindgame
Old Apr 2, 2005 | 01:02 AM
JDW18's Avatar
im workin on rebuilding my lt-1 into a 355 and im definately going with scats stock replacement crank and then forged rods and pistons seein there replacement cranks are good for 500hp which isnt bad seeing i dont plan i getting any more power then that anyway maybe some forced induction and thats about as far as i plan on going
