View Full Version : LT1 Based Engine Tech
- Will I gain anything with a LT4 intake?
- knock sensor
- Engine Swap
- alarm woes
- Dyno Experts Inside....
- Best Power Pulley's???
- Replacement clutch kit.
- Will this supercharger fit my camaro.
- ALDL to RS232 / 160/8192 bps / GM OBD-1 ECM DIAGNOSTIC CABLE?
- intake/injector cleaning
- Pulling the engine in a 95Z?
- how to mig weld?
- Any one who knows anything about brakes
- Granatelli Mass Air Flow
- Front oil seal leak, what's the secret??
- What is the best place to send my 30lb. SVO Injectors to get serviced/rebuilt??
- Best stroker kit????
- Rebuild ?'s
- my heads are back from lloyd!!!
- squeeking after opti change
- Texas Smog Testing... Please Help
- Shreaking Noise
- Can oil leak cause water forming at oil filler neck ?
- Camshaft Advice Needed....
- Rear sway bar will not fit with TA cover. Any ideas?
- Shifter feels rough when moving into 2nd
- How do I know the size of my belt? (March underdrive pully)
- I Love Slp!
- What could cause fuel pressure to do this??
- Crazy Dyno sheets w/n CC306, ect.
- Legal Cams?
- New MAF, which should i get?
- Stumbling Problem update/BIG KUDOS TO JAY FISHER PONTIAC
- Gm 847 Questions
- Doing headers have a few ???
- Chip for an LT1
- Not your usual Air pump thread
- scanmaster instructions(paperwork)
- What does a BURNT Valve look like?
- sigh...3rd header bolt on drivers side and..
- What to get with about $300
- Quick Question: Any differences in Speedo wiring harness between LT1/LS1?
- Donkey stick got suck up in TB
- Exhaust Side Exits...project. Anyone have junk GFX sides? Advice needed.
- stock vs turndown vs chrome tips
- Percy's header gasket, quick RTV question
- where to buy speedo recallibrator for 93 m6
- Moroso or Callaway
- Can someone explain this LT1 rwhp voodoo..?
- Possible to look at Dyno sheet and pinpoint problems?
- Please look at my new data file...
- Can anyone help w/wiring 94 LT1 to my 88 4wd pick-up?
- Any guesses ?
- 24lb injector upgrade question.
- Brake question
- Anyone know where to get a bra for my Z?
- optispark dilema
- What plug wires do you use?
- My thoughts on the ES mount
- LS1 vs LT1 Steering Shaft.. PICS INSIDE
- Check Engine Light and Fan came on tonite
- long tubes, 3.73s with or nittos, tc
- Cleaning oil off the car..
- vents still not working
- Frozen Doors
- tune up
- Anybody with SLP dual cat shorties AND 1" header bolts...
- WOW my 93Z have 300 psi
- Exhaust
- clutch problems
- blown head gasket..what precautions to take before I get to work on it?
- Who makes the harmonic balancer/hub assembley in one?
- Average cost of a stroker bottom end or 355?
- Anyone here using "light weight" brakes on there Fbody ??
- Edelbrock Lower Control Arms
- Code 134 Issues?
- Where is this rattle coming from???
- plugs/? which?
- Trick Flow Elbow ID vs. 1LE Elbow
- $70 for fuel system clean..Worth it?
- pic of exhaust on Lt1
- True Dual exhaust on a '95 Z-28?
- EGR Question
- Vacume Cannister...
- how big is too big?
- O2 sensor?
- CC 918 spring specs
- This normal? IAC counts at 15 after warm up
- 383's in here....Need some times and mods.
- Coolent Heaters
- NEED BOLT SIZE help ASAP!!!
- Took my car in for a recall, what does it mean?
- Stocl LT1 castings, 290 cfm.. possible?
- how to get rid of clutch pedal squeek in a m6!
- Sparks a fly!
- How can u get air in the front if you only changed the back calipers?
- Argh! my intake elbow is ruined!
- got a cutout ?
- How many people have spun cam bearings...
- Got LT's, What accessories do I need?
- Dual cat vs. single cat on the dyno.
- Vibes.....something bad?
- people with 236/242 or similar giant cams inside!!
- Dyno HP Vs. Torque &track times
- Alright got some $$$
- Madz28.com
- Patterns...
- 383 Stroker ?'s
- LT1 Conversion
- 98 lt1?
- I don't know what to call these problems...
- Ticking sound coming from oil pan area?
- Lt! Specs
- How do I get my dipstick out?
- Poping sound somethings lose
- dual exhaust
- 97 lt1 car ?
- Stock heads and 224/230 Questions Here
- Ported LT1 intake? Pics inside.
- Tall Valve Covers
- Rebuild Lt1/Lt4 book.
- Leaking 'Low Oil' Sensor
- people with 6sp & stock torque arm
- still need help
- Coolant Temp Sensor
- Plate help
- What size skinnies/tires for street?
- Car wont turn over somtimes unless i push the clutch in and out a couple of times
- questions on something I just bought
- !!!People in california!!!
- stock wheel size
- which Header gaskets???
- Basic head work
- Need Fast Help!!!!!!!!!!!!
- need help!
- heads/cam swap question
- hooker longtube owners. quick question.
- 1LE sway bars question
- Do local shops offer aluminum or copper header gaskets?
- Hooker CAT Back
- Cai
- dynoing tomorrow care to guess #'s
- LT4 intake, with cam
- All with 383's, please enter....
- Does anyone running an 847 have a dyno sheet to post??
- Stalling when shifting into reverse (cold start)
- Spring Tool
- Can I put a different muffler on my magnaflow exhaust???
- part #'s
- Do I need a re-program ?
- stock Y pipe, bolt size?
- My heater doesnt heat all the time!!!
- Wow, HOTcam, ported heads, stalled auto=21.7mpg
- ???????'s about T56 changeover
- Torquing header bolts???
- Idle fluctuation?????
- aiming fog lights...
- 3rd --> 4rth what happened?
- Problems, acts like miss @ highway speed, PLEASE PLEASE LOOK
- Keeping fog lights on with hi and lo beams
- ac pulley
- Question about a muffler!
- What does the Lt in lt1 stand for?
- cam break in
- Need a few random camaro screw sizes
- Help me find out what's wrong
- Vibration/ Rough running at all rpms, yet worse at high speeds?
- lt 1 tech
- What is the best Ignition Coil to replace my Stock Coil on My 1997 Z28?
- Injectors
- Has anyone installed a 52mm tb and not had it idle high?
- Mobil 1 synthetic
- Best shift kit?
- Large cams and ignition timing?
- Are LT1 motor mounts the same as any sbc?
- GM 847 users, valvetrain question for you..
- Anybody have a problem where the middle primaries on the header won't seal???
- Valve Spring Retainers
- Rebuild
- My car is dead...
- Looking for something HELP
- need a link to the HUGE fbody manual
- Simple headlight question
- Fuel pressure regulator??
- stock-y-pipe?
- Valve covers
- white smoke from throttle body/manifold?
- Cam help please
- Loss of power....Exhaust leak?
- Rear Defroster only goes on for about 10 sec
- Popping noise from intake??
- Who has LT headers w/o OVC wires?
- trick-flow elbow come with orange or black hoses?
- Transmission install
- 02 Steering Wheel on 95 ????
- Pattern?
- My car has no endurance!!!
- ZZ9 Cam???
- best almost stock lt1 times?
- LT1 - to - LS1 Front & Rear Brake upgrade ???
- Part Number Request
- manifold vacuum source?
- Those With MAC Headers: Did you coat them or not!?!?!?!!?
- easiest way to program computer
- Which is better in snow?
- Lt1 ---> Lt4
- 302 questions
- Best place to get engine rebuild kit?
- Flowbooster/ airfoil question...
- What's making this ticking sound??
- Is this hub installed correctly?
- Bottom end strengthening on 2-bolt block
- Ignition
- Vaccum Modulation ?
- What will a dead cylinder look like to the PCM?
- '93 heads in comparison....?
- True Duals Owners
- cheapest place to buy an SLP 2OTL catback?
- I'm finally in the 4 fourth gen message board
- LT-4 valve Covers
- Opinions on TEA heads....
- Help.....Crankshaft Hub Install ?
- Please help me figure this out
- Clutch Pedal
- RR/LT4 valvespring Dyno results...
- Vibration/Wheel hop
- max rpm on stock bottom end
- OBD II to OBD I
- Which Headers would YOU buy? My Last Header Question!
- What are the biggest brakes I can get...
- JETHOT slip-in #1 primary weld it?
- 15" weld wheels
- Quick question on adjusting valves. PLZ HELP :)
- A/C cold air leak into engine bay
- Lighting upgrades.
- Crate motor will it fit
- How does one get a wheelie?
- I'm a fool. It wasnt my opti.. :(
- LT4 cams???
- Electric Cut-Out
- PIAA foglights
- How do i remove a-pillars?
- 227/233 Dyno Results
- Problems with Canton pan( Canton pan and HV pump users inside)
- Just curious...
- Woa!
- BAD Day @ the dyno
- Car won't start! Need help now! Stuck at U of Evansville
- emissions unsure why
- Anti Theft System
